TwinTurbo.NET: Nissan 300ZX forum - There are two adjustments, but only one is usually
ttz'in (NorCal)
on February 07, 2011 at 10:43 AM
e-brake doesnt work anymore :(
posted by RonDeezy
on February 07, 2011 at 05:34 AM
required, Remove center console and adjust 10mm nuts so that you get 6-7 clicks on the lever. If cable is really "stretched" you will have to start at "Y" adjuster above the rear end.
RonDeezy
05:34:33 02/07/11
There are two adjustments, but only one is usually -
ttz'in (NorCal)
10:43:49 02/07/11
*just unsnap the ebrake handle boot/cover.
Woody75 (Denver)
12:05:57 02/07/11
i did it before from the rear end
Jiro
23:32:01 02/07/11
Actually you need to do both locations.
Woody75 (Denver)
07:30:35 02/08/11
Part 2
Jiro
23:35:18 02/07/11
